May 28, 2012, 01:37:54 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  VB and Busy
Pages: 1   Go Down
Print
Author Topic: VB and Busy  (Read 1264 times)
newtocnc
Active Member
Offline Offline
View Profile
« on: June 08, 2008, 02:43:04 PM »
hello everyone
Is there a like isBusy() command in VB.
when I do refresh like REGEN the toolpath tru VB.
I can not read some of the dro's.
If I single step No problem.
Thanks.
rayscott
Active Member
Offline Offline
View Profile
« Reply #1 on: June 16, 2008, 12:40:22 PM »
Ther is a command to see if the machine is moving..
DO WHILE ISMOVING
   REM * DELAYS THE CODE UNTILL PRIOR g MOVEMENT IS COMPLETED
LOOP
Good?
Ray
Pages: 1   Go Up
Print
Jump to:
