Hello Guest it is June 10, 2026, 12:05:39 AM
Author Topic: Z height adjustment  (Read 7637 times)
Z height adjustment
« on: June 07, 2008, 12:53:22 AM »
Hello everyone,
I like to change Z values from a user DRO,
without affecting the G code and rerun the program
Can one do that in vb.
I cut thin uneven parts. sometimes I need to do several cuts,
to get it right.
john
Re: Z height adjustment
« Reply #1 on: June 07, 2008, 10:57:38 AM »
Hello john,
I did similar task (engraving in uneven parts with minimum engraving depth, but all within the material) by the help of limiting z depth. The G-code contains a much too deep z value and by limiting z to e.g.-0.10 and slightly increasing this limit (-0.15, -0.20) I got the required result.
Holger
« Reply #2 on: June 09, 2008, 03:07:10 PM »
THanks Holger,
That approch work quite well.
I was hoping not to put max Z value in the code.
Sometimes one forgets to click the Z llimit function,
that is when the fun starts.
thanks
