Hello
Guest
it is
June 08, 2026, 11:19:30 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
incremental feed
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: incremental feed (Read 10124 times)
ayhan
12
incremental feed
on:
April 15, 2008, 03:21:27 AM »
Hello everyone,
Is there any way to increase the feed in the same line ?
For example: it will start F100 at the end of the distance will be reached F200
Thank you
Ayhan
jimpinder
1,232
Wakefield, West Yorks, UK
Re: incremental feed
Reply #1 on:
April 15, 2008, 03:59:38 AM »
You do not say what you are trying to do.
If you are on a lathe and taking a facing cut across the work then you are talking of CSS Constant Surface Speed. This is available on Mach3 if you have the necessary control of your motor spindle.
Other than that I cannot begin to understand why you want to increase the feed rate - i.e. the speed the tool moves - as you progress along a cut.
ayhan
12
Reply #2 on:
April 15, 2008, 04:12:14 AM »
Sorry I forgot to say ,
I need axis increment feed, not spindle.
For example X at ziro
G01 F100 x20
X starts as F100 and finish as F100 no problem.
But What I need is X should start as F50 and increase to F100 (In 20mm)
Thank you
Ayhan
Print
Pages:
1
Go Up
« previous
next »
