Hello
Guest
it is
June 09, 2026, 11:50:26 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Calibration???
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Calibration??? (Read 9840 times)
Biotech1
3
Calibration???
on:
April 13, 2008, 04:07:38 PM »
Puzzled
i made 2 1 inch squares and 2 1 inch circles I pocketed 1 square and one circle it came out at .9998 and when i do the profile outside its bigger than 1 inch and I'm using a .125endmill with vcarve pro.... any suggestions as to why its perfect one one and real crappy on the other...
Chip
2,055
Gainesville Florida USA
Re: Calibration???
Reply #1 on:
April 13, 2008, 06:01:10 PM »
Hi, Biotech1
So what's the, "real crappy on the other..." values.
Not to much info in your post to work with, Is it Backlash, Flex.
Thanks, Chip
DAlgie
314
Re: Calibration???
Reply #2 on:
April 13, 2008, 07:12:09 PM »
Mill bit is too small, it's walking around one way on the inside cut and the other way on the outside cut. Use as big a mill as possible when you can.
Print
Pages:
1
Go Up
« previous
next »
