Hello Guest it is June 11, 2026, 09:59:56 AM
Author Topic: Homeing All Axis not working properly  (Read 26964 times)
Re: Homeing All Axis not working properly
« Reply #10 on: May 15, 2006, 08:58:03 AM »
It is doable... But you are going to have to write your VB script to probe the tool. I hope to have time to make the scripts but it is going to be some time... But if you work on it I wil help :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #11 on: May 15, 2006, 10:21:40 PM »
I did alittle vb scripting about 3 years ago.  nothing major.  just angle formulas i didnt feel like doing over and over again. What kind of vb script are we talking about?
Just to ask.  What cause noise in the line like i got on my home switches?  Bad wires?  Bad connections?  Because the wire i used for my home switches is cheap speaker wire.  i had to get the machine up and running asap so no time to get anything better.  So i just threw it in.  Any suggestions on a bitter choice for wires for homes?  also any suggestions on the best home limit switches?  i still need to get home for my Z and limits for all my axis.  And still need to wire into my estop.
« Reply #12 on: May 17, 2006, 08:51:18 PM »
The noise is from other wires in your system... If you have power wires running along side the logic wires you can pick up noise...
www.machsupport.com
