Hello Guest it is June 13, 2026, 04:41:56 AM
Author Topic: Using linear glass encoder  (Read 10351 times)
« on: April 04, 2008, 01:16:34 PM »
        I'm buying an linear glass encoder to use with X and Y axis (5um , A and B TTL signals). Someone knows if Mach3 can read the linear encoder outputs with I use an feedrate value of 500 units/min (mm/min)?
         I'm afraid of that using feedrate values such high like 700mm/min, the linear glass encoder output frequency (A and B) too high, that parallel port can't read these signals.
Re: Using linear glass encoder
« Reply #1 on: April 04, 2008, 01:51:07 PM »
Mach could read my 5um scales at 2500mm/min so your 700mm/min wont cause a problem at all.
« Reply #2 on: April 04, 2008, 01:53:53 PM »
Ok, thanks a lot.  ;D
