Hello Guest it is June 13, 2026, 03:21:32 AM
Author Topic: DRO # for Steps Per Inch/mm  (Read 12705 times)
« on: April 03, 2008, 10:48:45 AM »
I need to be able to access the number of steps per inch/mm. The DRO is located under Config-Motor Tuning. If anyone knows how to get that number, please tell me.
Thanks alot. :)
Carl
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: DRO # for Steps Per Inch/mm
« Reply #1 on: April 03, 2008, 02:52:02 PM »
Hi, Carl
Do the other menus open up under "Config" pull-down list ? (Could have a password set under Operator if none of them will open).
If it won't open the "motor tuning" window only in Mach3, (I've had this happen several times in the past) You'll need to reinstall Mach3.
Make a copy of your Mach3Mill.xml or what ever it's named (profile you load/run with Mach).
It's located in C:\Mach3 folder (standard install for Mach).
Hope this Helps, Chip
« Last Edit: April 03, 2008, 03:02:12 PM by Chip »
« Reply #2 on: April 03, 2008, 03:01:55 PM »
I'm sorry, I should have been more specific. I need to use the value in a brain, so I want an address or DRO number. Other wise, every time I change it I'll have to do it twice. I'm trying to design a new screen.
Thanks.
Carl
Offline Chip
  •  2,055 2,055
« Reply #3 on: April 03, 2008, 03:08:09 PM »
Hi, Carl
I think that's an internally used xml value. Have a look hear though
http://www.machsupport.com/MachCustomizeWiki/index.php?title=Main_Page
Thanks, Chip
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #4 on: April 03, 2008, 03:25:35 PM »
The function is
GetParam (name as String) as Double
The string you want is "StepsPerAxisX"  or Y or Z etc.
« Reply #5 on: April 04, 2008, 10:16:55 AM »
That did it. Thanks so much!
Carl
