Hello Guest it is June 11, 2026, 11:18:01 AM
Author Topic: USB Camera  (Read 11802 times)
Offline Psad
  •  82 82
USB Camera
« on: April 01, 2008, 10:50:37 AM »
In the winter 2007 editionl of "digital Machinist" theres iis artical for building a USB camera edgefinder.
that dscussion references software found on Mach3 to view the camera output.  Can someone point me to the link for that software, routine, plug-in etc. ???
Re: USB Camera
« Reply #1 on: April 01, 2008, 11:19:52 AM »
I have used the camera and it can be good for measuring from a line ie say a printed circuit board.
But for edge finding you cant beat a probe.
There is a guy selling them on the for sale section.
That's what i use i have tweaked mine a bit but they are excellent value for money.
The probe routine is only active when its enabled in ports n pins
He doesn't supply a dedicated macro for it which is a shame as i had to spend a long time working it all out.
I made a setting block to set it up now not only edge finding Built In, Probing Built In Centre of hole finding Built in.
I would say its accurate to .0002" once the probe is on the machine it will take 15 second to find the centre of a hole.
In actual fact i would say the probe has been one of the most beneficial things i have on the machine to enable ease of use
I made my own Z setting tool/probe as the normal piece of wire on a touch plate will not when when using a probe
The reason being the probe is break to make and a touch plate is touch to make HTMS
Strangely Z zero setting is not built into Mach ? The button is  there but no code behind it
HTH
Phil_H
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: USB Camera
« Reply #2 on: April 01, 2008, 01:25:47 PM »
Mach 3 already has the routine for the camera installed in "Plug In Control"
The basis of this is that a suitable camera can be mounted on the lathe, chuck, milling head etc i.e. any suitable place on your machine and focus on another place - i.e. mounted in the milling chuck and looking down on the workpiece. The software already has a set of crosshairs electronically engraved on the camera output.
The downside is that it doesn't always work, - especially with the modern USB camera working under Windows drivers.
The cameras usually need USB 2.
They seem to be alright if the camera has a disc with a set of drivers in that you can manipulate, but some, running on the internal Windows drivers  - all Mach 3 says is unable to open the camera driver.
