Hello Guest it is June 13, 2026, 03:21:45 AM
Author Topic: Lubrication of belts and racks  (Read 14854 times)
« on: March 31, 2008, 10:20:00 PM »
Hi all,
Can anyone give some advice on lubricating: 1.  timing belts and 2. Rack and Pinions. Do they require lubrication?
My thoughts are that the lubricant would attract dust build up.
 Maybe some type of silicone spray may work?
(I have just spotted the other forum sub sets! I will use "Tangent in future" Thanks Bret)
Bruce
« Last Edit: March 31, 2008, 10:30:59 PM by MachBruce »
Re: Lubrication of belts and racks
« Reply #1 on: April 01, 2008, 03:05:42 AM »
Timing belts shouldnt need lubed, I would imagine racks may need it though. Probably your silicone  spray would work, if not then maybe just using a light oil would help minimise dust collection.
« Reply #2 on: April 01, 2008, 05:47:42 AM »
Thanks, Hood
I just tried a smear of Vaceline on the new belts.  Now  whisper quiet.
Bruce
« Reply #3 on: April 01, 2008, 07:16:32 AM »
Another one of the many uses Vaseline has been put to :D
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #4 on: April 01, 2008, 11:39:31 AM »
 ;D ;D ;D - speaking of which - I wonder if there's any petroleum based plastic or particularly latex in the belts - given .... erm... certain erm.... things.... shouldn't be used together... maybe not a topic for this forum.
Oh just google latex vaseline  ::)
« Reply #5 on: April 01, 2008, 02:56:28 PM »
Well if your belts get pregnant you could start up selling them at half the price of the bearing supply houses do :D
Offline GaryB
  •  108 108
« Reply #6 on: April 01, 2008, 04:54:35 PM »
I use Lubriplate 630AA on the rack & pinnions of both my machines. Its a multi-purpose grease for bearings, gears and cams, best part it doesn't attact dust, nothing on the belts I run them dry
Beckwith Decor Products
ArtCam Trainer
Onsrud & Custom CNC tooling Distributor
Wichita/Derby Kansas
http://www.beckwithdecor.com
« Reply #7 on: April 01, 2008, 05:10:41 PM »
As Stirling stated...I wonder if there's any petroleum based plastic or particularly latex in the belts. Oil will indeed rot rubber. Thats one reason why your not supposed to use WD40 on your vehicle door sills in the winter. It might solve one problem at the moment, but creates a much more serious problem later. The 2 do not play nicely together. You could buy some KY jelly for your belts.  ;D Might wanna tell the wife what your doing before she stumbles upon a tube of KY in your toolbox, though, because yet again... It might solve one problem at the moment, but creates a much more serious problem later.  ;D  ;D Seriously though, I wouldn't think belts would need lube. If you feel that they do, my first thought would be some belt dressing from the auto store.
« Last Edit: April 01, 2008, 05:14:18 PM by Sam »
« Reply #8 on: April 01, 2008, 10:42:06 PM »
I just had a thought, that there are rubber preservative/lubricasnts available from auto acc. stores armerall the stuff you spray on plastic and rubber seals - should work fine. Which is cheaper "armorall "or "KY" decisions decisions.
