Hello Guest it is June 12, 2026, 03:24:32 PM
Author Topic: Waynes Leadwell VMC Retrofit  (Read 129584 times)
Re: Waynes Leadwell VMC Retrofit
« Reply #30 on: May 09, 2007, 04:40:19 PM »
I have done that in the past :)
www.newfangledsolutions.com
www.machsupport.com
Offline fdos
  •  326 326
« Reply #31 on: May 09, 2007, 05:35:44 PM »
Boring Innit!    Thought someone might be inspired if I posted it though ;)
Not enough vids of machines working in here!   Lets see some more.   When the Hardinge is running I'll be sure to show a job or two.
The ability to host on Youtube is useful though ;)
Wayne....
« Reply #32 on: May 09, 2007, 06:15:58 PM »
I was thinking that I was the only one here that could not throw out the old taps :)
Keep up the great videos!
www.machsupport.com
Offline fdos
  •  326 326
« Reply #33 on: May 09, 2007, 06:33:40 PM »
LOL   Old endmills have a multitude of uses.   Make excellent boring bars for lathes too ;)
Here's a recent recent 2nd lifes for old old cutters.
1st 2 are threadmills including the one in the video (HSS) the smaller threadmill is an old solid carbide cutter, I use that for 0.75mm pitch internal threads on model aero engines.
The other pic is a form drill which drills for 1/4" whit tap, chamfers the hole and creates a spotface all in one operation.
Wayne....
« Last Edit: November 07, 2007, 05:04:15 AM by fdos »
Offline fdos
  •  326 326
« Reply #34 on: May 12, 2007, 11:33:44 AM »
Don't know if you all remember the little video of the radcaps.  Well I just finished a small batch, and they have turned out pretty well I think.
The threadmilling vid was for this job too.   I won't threadmill them next time though as I hope the hardinge will be running by then, that machine will be a lot quicker.  That all depends on spindle syncing with the G100 of course ;)
Anyway here's little pic.
Wayne....
« Reply #35 on: May 12, 2007, 08:23:51 PM »
Good job Wayne. I knew it would be, I saw them in the making. Keep up the good work and keep posting.
« Reply #36 on: May 13, 2007, 02:32:10 AM »
Nice Wayne
 couple of questions, how did you do the domed top, in a lathe? how did you fix the insert into the acetal? If its a trade secret dont worry LOL
Offline fdos
  •  326 326
« Reply #37 on: May 13, 2007, 07:14:37 AM »
Hood.  The top was indeed cnc turned, on the one machine I do have running!
Hmm the bonding!   Kinda a trade secret;)   Acetal is VERY difficult to bond to ANYTHING.  But it involves an adhesive, a  sloppy lefthand interupted thread! (Enough clues?)
Wayne.....
« Reply #38 on: May 13, 2007, 08:05:42 AM »
yep, sounds like a similar method that I used, was hoping you had a better way ;)
« Reply #39 on: April 30, 2009, 03:58:16 AM »
Hello Wayne.
I have been reading this thread with a big smile:-)
I have just bought my self an leadwell GMC 600 with an old CNC Meldas system that is brooken.
I  did not understand if you did change the servos to steppers or you did use the mitsubishi AC Servo motors?
How have you done with the spindel motor? Do you use the orginal mitsubishi Servo motor and the Freqrol FR-SF inverter or have you replaced it?
Best Regards
Oscar Larsson
