May 28, 2012, 01:14:15 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Finished Screens
| | | |-+  TurnSilverBlue.lset screen is black
Pages: 1   Go Down
Print
Author Topic: TurnSilverBlue.lset screen is black  (Read 3541 times)
Ben
Active Member
Offline Offline
View Profile
« on: March 28, 2008, 08:26:41 AM »
On one computer it works fine but the shop computer the whole screen is black except the reset led and the click areas are there but no graphics. I've used the same xml file. What should I check? Thanks, Ben
Graham Waterworth
Administrator
Online Online
West Yorkshire, England
View Profile WWW
« Reply #1 on: March 28, 2008, 11:50:34 AM »
Check you have all the icons/screens in the correct directory within Mach3.
Graham.
G-Code is on the cutting edge
Autovalues Engineering, CNC machining specialists, Bradford, England
Ben
Active Member
Offline Offline
View Profile
« Reply #2 on: March 28, 2008, 12:38:38 PM »
Thanks Graham, I had opened the zip in the wrong directory. Ben
backyardcnc
Active Member
Offline Offline
View Profile
« Reply #3 on: March 31, 2008, 01:54:30 AM »
So what is the "right directory"? I have downloded this screenset for MACH3TURN and the MANUAL/TOOL screens are normal and the AUTO and DIAG screens are mostly black. When I ran the initial file it said that it was corrupted. I downloaded again but still the same. It sure looks nice though and I would really like to get a working version!
Gerald
backyardcnc
Active Member
Offline Offline
View Profile
« Reply #4 on: March 31, 2008, 02:05:09 AM »
Forget my last post, solved the problem. Downloaded again fr 3rd time and install went AOK and all screens work! Sure looks nice!
Bet my lathe makes much nicer chips now............
gerald Roll Eyes
Pages: 1   Go Up
Print
Jump to:
