Hello Guest it is June 10, 2026, 03:11:39 AM
Author Topic: g-code problem after loading to mach3  (Read 11664 times)
« on: March 20, 2008, 08:17:16 AM »
hello, everyone,
i'm having a problem when i load a g-code from lazy cam to mach 3. The thing is that when i load it the first time i can see it all without any problems with the g-code. If i close mach 3 or regenerate it, then i can only see half of the image and the g-code is  bad!
am i missing something?
please help!
thanks in advance!
Re: g-code problem after loading to mach3
« Reply #1 on: March 20, 2008, 12:08:14 PM »
Can you attach the code please.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #2 on: March 20, 2008, 02:45:40 PM »
To: Post your G-code File
If you have a Standard Install of Mach you'll find the File in C:\Mach3\Gcode folder.
Use the "REPLY" Button then Attachment Options, "Browse" to C:\Mach3\Gcode and find the file, Double click on it and Post.
Hope this Helps, Chip
« Reply #3 on: March 20, 2008, 02:50:42 PM »
it's a simple newbie cut!
« Reply #4 on: March 20, 2008, 03:49:25 PM »
Seems to work fine here, can you take a screenshot to show what you are seeing for the toolpath.
« Reply #5 on: March 22, 2008, 07:14:13 AM »
Found the problem!!!!
Beware of  windows installer 3.1 [ kb893803]
When instaled, disable the driver of mach 3 cause it will cease it.
thanks
