Hello Guest it is June 09, 2026, 05:14:10 PM
Author Topic: Chucks – LED City set  (Read 47634 times)
« on: March 18, 2008, 07:29:30 PM »
Let me know if there are any problems or suggestions.
Just hit any bottom button a second time and the MPG will pop out.
« Last Edit: March 26, 2008, 11:54:19 AM by chucky »
Re: Chucks – LED City set
« Reply #1 on: March 18, 2008, 08:41:42 PM »
Looks great Chucky, nice.
« Reply #2 on: March 19, 2008, 04:30:26 AM »
thx
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #3 on: March 20, 2008, 01:26:02 PM »
Nice work looks great..great colors..easy on the eyes..can see from far away..nice  :)
« Reply #4 on: March 22, 2008, 11:59:21 AM »
Updated the file at bottom of post #1
Changed the point to point screen
 Added feed for x,y and separate one for z
 Added drill and peck
Changed some button codes
The drill stuff will not work with the new Version R3.038 for some reason. --Edit works fine with Version R3.039 now
« Last Edit: March 23, 2008, 09:12:58 AM by chucky »
« Reply #5 on: March 23, 2008, 03:13:32 AM »
 :o
Hello,
this is super work, thank's
Fabrice
« Reply #6 on: March 23, 2008, 08:39:07 AM »
Chuck, you're an artist, my friend and this is a wonderful screen set, thanks so much for your hard work  :)
« Reply #7 on: March 23, 2008, 09:09:46 AM »
Thank you
Here is an update set that gives the point to point screen a whole lot more help, status and info while things are running.
Rename the file to Chucks.set
EDIT See below for file
« Last Edit: March 25, 2008, 07:34:40 PM by chucky »
« Reply #8 on: March 23, 2008, 01:41:37 PM »
This new set will only use x,y feed rate below 0.0000 Z-axis for milling and 100% for moving above 0.0000.
Edit see blow for DL file
« Last Edit: March 25, 2008, 04:20:25 PM by chucky »
« Reply #9 on: March 25, 2008, 04:19:40 PM »
This point to point update has 2 basic modes
Auto – when you first open it will.
Turn on the spindle and wait for coolant to prime and use feed rate any time you move and below 0.0000 on the z-axis for all axis.
When you are above 0.0000 z-axis it will use rapid rate for all axis moves.
If you move the z-axis from a +number to a  - number it will go to .120 stop turn on spindle wait for coolant to prime then cut.
Any z-axis move up will use rapid rate.
Manual – hit the manualbutton will.
No matter what move you make they will always move at the rate you set with no spindle stuff.
I also added the ability to set the x and y axis separately for each of the 9 points and more status info.
« Last Edit: March 26, 2008, 11:55:31 AM by chucky »
