Hello Guest it is June 09, 2026, 08:45:26 AM
Author Topic: Help with spindle speed command.  (Read 10833 times)
« on: March 18, 2008, 04:15:31 AM »
Hi guys,
I recently got my spindle to start running.  I'm running into some trouble which I can't seems to understand.
1) Mach3 doesn't seems to like my M-code
eg1.
G90 G64
 M6  T1 (TOOL CHANGE center_5) (MSG, LOAD TOOL # 1)
G0 G54 X0.4927 Y-0.5938
M03 S978
eg2.
G0 Z0.1
 G54 X1.362 Y-1.35 S769
It will always bark at any of the lines with "S" in it.
2. If I set my pulley1 for 200-3500 is there any reason why max limit error occur @ 2500 RPM and limit out at 2500 RPM.
3. If I only have one pulley between my motor and spindle (Syil SX3) where my typical "manual" speed range is 200-3500 RPM, what should I set my pulleys 1-4 and is there anything else this newbie should set.
Thanks.
« Last Edit: March 18, 2008, 04:17:03 AM by JonnyD »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Help with spindle speed command.
« Reply #1 on: March 18, 2008, 04:27:02 AM »
If you look at the settings page you will see the pulley number in use, it is the correct one?
Graham.
« Reply #2 on: March 18, 2008, 05:47:42 AM »
Graham, I did read through section 5.5.6 Spindle motor setup several times that's why I set my pulley #1 to 200-3500 with a 1:1 ratio.
The reason why I asked the redundant question#3 is because when I was second guessing myself.
Anythow, I think the issue of limit error is a "User Error", most likely I didn't save the settings prior to proceeding.  I went back and change pulley 1-4 to have the same settings 200-3500 with a 1:1 ratio then select pulley #1 and save and so far I don't get the error of max limit.
The other part of question #2 is probably the problem with Syil spindle control board.  I see in the other forums that a few ppls report them being off.
That still leave question #1 open.
