Hello Guest it is June 11, 2026, 07:00:05 PM
Author Topic: Griffin powermate doesn´t work. Need help...  (Read 10916 times)
« on: March 11, 2008, 11:44:09 PM »
I have installed Griffin PowerMate, but the only thing it does is to change between axis in the status window. When I turn the wheel, nothing happens.
Do I need to change any configurations in Mach3?
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Griffin powermate doesn´t work. Need help...
« Reply #1 on: March 12, 2008, 04:09:54 AM »
The Griffin site doesn't give any clue.
What are you trying to do with it.
« Reply #2 on: March 12, 2008, 06:04:18 AM »
I try to jog the axis by rotating the wheel, but nothing happens.
Offline jimpinder
  •  1,232 1,232
« Reply #3 on: March 12, 2008, 09:57:33 AM »
If you look under Config/System Hotkeys you will see the box for setting the keys to jog the axis.
You can set whatever keys you like to jog the axis.
I assume the Griffin puts the equivelant of keyboard strokes into the computer, so select which jog you want to configure, e.g. X++ and then press a key, or do what you want to do with the Griffin and see if it registers.
If the Griffin is a rotary switch - i.e. you turn it, I cannot see how you can replace a keystroke with it. In Mach3, if you press a "jog" key, the jogg continues until you release it. It is not a mouse like function with continuous movement.
