May 28, 2012, 11:42:43 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Works in progress
| | | |-+  The start of Mach Blue Lathe for those that requested a Lathe Set
Pages: « 1 2   Go Down
Print
Author Topic: The start of Mach Blue Lathe for those that requested a Lathe Set  (Read 6509 times)
Graham Waterworth
Administrator
Online Online
West Yorkshire, England
View Profile WWW
« Reply #10 on: May 07, 2006, 08:39:25 AM »
Its here,
Graham.
G-Code is on the cutting edge
Autovalues Engineering, CNC machining specialists, Bradford, England
mrbean
Active Member
Offline Offline
View Profile
« Reply #11 on: May 07, 2006, 08:44:33 AM »
Thanks guys.
As you can tell I'm not familiar with the lathe stuff.
In fact the first time I even looked at the lathe module, was when Santini suggested we do our "Blue" theme for it.
Thanks again.  This clears things up.
Bloy
Active Member
Offline Offline
View Profile
« Reply #12 on: May 08, 2006, 04:33:39 AM »
Hi Mr Bean,
  In the configs/turn options there is an option for radius or diameter mode...
Is this what you are looking for?
I'm sorry MrBean, I left out a key (ports and pins) part of the path.   Gee good thing there are others make up for my missing marbles.   Smiley
Once can be too much, but never is not enough
mrbean
Active Member
Offline Offline
View Profile
« Reply #13 on: May 08, 2006, 06:25:28 AM »
No problem.  We all have missing marbles at times.
I think we've found all the "Dynamic" labels now and sorted these out.
Cheers.
santiniuk
Global Moderator
Offline Offline
View Profile
« Reply #14 on: May 09, 2006, 05:42:45 PM »
For anyone interested the screenset is open for download and test :-
http://machsupport.com/forum/index.php?topic=632.new#new
Thanks for the original feedback. The static labels caught us both out Smiley
Pages: « 1 2   Go Up
Print
Jump to:
