Hello Guest it is June 11, 2026, 10:41:41 PM
Author Topic: Laptop requirements with Mach 3  (Read 147454 times)
Re: Laptop requirements with Mach 3
« Reply #20 on: October 17, 2008, 07:38:13 AM »
 Thanks for the quick reply.
 I thought it might be the case.
 But looking on the bright side. It takes the same amount of time to boot as it does for me to make myself coffee.
 So I think that works for me.
 Jason
« Reply #21 on: May 17, 2009, 04:41:58 PM »
Just want to say thank you so much to whoever figured out this trick. My Dell Latitude laptop wasn't working at all and then I reconfigured the ACPI driver to standard PC and it works beautifully now.
  •  9,356 9,356
« Reply #22 on: May 19, 2009, 06:47:13 AM »
This is certainly a good forum with so many people sharing their ideas and solutions to problems.
« Reply #23 on: October 05, 2009, 02:28:03 PM »
I have ACPI and when I go to update it, it doesn't give me an option to choose standard.
How can I make it do standard instead of giving me the same ACPI?
Hoppy
« Reply #24 on: November 19, 2011, 01:28:33 PM »
Hoppy
Mine does the same thing.... any ideas?
« Reply #25 on: June 08, 2012, 11:17:20 PM »
Will Mach 3 work on a Toshiba laptop running WIN7 64B and tied to a MAXNC15
« Reply #26 on: August 25, 2012, 09:54:17 AM »
I am using an HP nx6110 with Windows XP Pro with no problems. It has an integrated serial port and it has worked perfect. I have not changed any power saving settings or done anything special to it.
« Reply #27 on: July 22, 2016, 05:32:27 AM »
I just bought this laptop http://www.laptopoutlet.co.uk/lenovo-ideapad-305-green-15-6-core-i3-laptop-intel-5005u-8gb-ram-1tb-win-45.html and can anyone explain is it well enough to run Mach 3 or should I replace my laptop???
  •  9,356 9,356
« Reply #28 on: July 22, 2016, 06:28:55 AM »
Looks like a good deal to me - now you need to decide on which external motion controller you are going to use.
« Reply #29 on: July 22, 2016, 06:34:40 AM »
Fine, Thanks for the reply.  ;)
