May 28, 2012, 11:37:28 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Interfacing to a PCI card
Pages: 1   Go Down
Print
Author Topic: Interfacing to a PCI card  (Read 1396 times)
Ruanb
Active Member
Offline Offline
View Profile
« on: February 21, 2008, 03:28:18 PM »
Hi all
I hope someone can guide me in my quest.
I have a lathe I've been battling years on. A "ancient" Okuma. Now I've bypassed the old control and managed to get those enormous motors running on Mach3.
But now I want to run both my turrets as well as my spindle from Mach3.
A little background on the turrets: They consist of a 4 position front and a 6 position rear. They are controlled by relays and ordinary switches. The relays are switched in combination to achieve desired tool position. I have all the electrical schema's etc.
The spindle. It is a automatic 6 speed gearbox which gives out 12 possible running speeds. Also controlled by relays.
Now for the help part I need:
I bought a PCI card which is installed within my PC which can controll 32 out and 8 in I/O's. I have written a program which succesfully does what I need it to do in VB. BUT I would like to interface it to Mach3, I can write basic VB, and I do not know C++ at all.
What would be the best way of doing this, Macro's VB Script or .........C++
Any guidance will be greatly appreciated.
Regards
Ruan Basson
South Africa
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #1 on: February 22, 2008, 08:17:55 AM »
Not being very clever at this, but I would suggest using the coolant on /off functions (M7,M8,M9) to control the turrets ( via the existing LPT1 port outputs)  and just turn the coolant on / off with the spindle function (M3,M4,M5). Does this make sense ?.
Best regards,
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Ruanb
Active Member
Offline Offline
View Profile
« Reply #2 on: February 22, 2008, 02:43:37 PM »
Hi Tweakie
I thought about it, but I have to many outputs that needs to be trigered.
My front turret has one relay to identify it, then 4 3 relays to trigger the T commands. The back turret have in total 7 relays, then there is the spindle which needs another 7 relays at minimum, that is if I want only CW, there is other relays for controlling the rolling, relays for telling the control when tha gears have been changed etc.
I thought of adding another LPT as well, but I would still be a few outputs short.
DAmn................. If I could only afford a PLC...... Huh
DennisCNC
Active Member
Offline Offline
View Profile
« Reply #3 on: February 22, 2008, 09:58:55 PM »
Here you go the cheapest and easiest PLC ever!
http://cubloc.com/product/01_01cb405.php
I use it will mach3 through serial modbus and works perfect.  If you need help setting it up just ask.
Pages: 1   Go Up
Print
Jump to:
