May 28, 2012, 11:36:54 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Brains Development
| | |-+  Newby – brains to turn the coolant on/off ?
Pages: 1   Go Down
Print
Author Topic: Newby – brains to turn the coolant on/off ?  (Read 1804 times)
chucky
Active Member
Offline Offline
View Profile
« on: February 20, 2008, 02:40:41 PM »
I am trying to make a brain to turn the coolant on only when the G-code is running and the Z-axis gets with-in .125 from the part and lower.
Any hints?
My coolant or mist is on output 4
thx chuck
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #1 on: February 20, 2008, 11:31:26 PM »
Ok here is a brain,
It looks at the Run LED, and Z position dro, (assumes -Z is going down into your work, and 0 is the work top surface).
it then turns on output4 when z is less than .125
scott
* CoolentBrain.brn (2.47 KB - downloaded 270 times.)
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
chucky
Active Member
Offline Offline
View Profile
« Reply #2 on: February 21, 2008, 08:54:52 AM »
Thanks a million poppabear it works like a champ and helped me figure out how this works.
Pages: 1   Go Up
Print
Jump to:
