Hello Guest it is June 10, 2026, 04:12:07 AM
Author Topic: Mach with Kmotion USB controller  (Read 11091 times)
« on: February 17, 2008, 03:27:45 PM »
Any one try this controller out yet:
http://dynomotion.com/
click on videos on the left then Mach plugin.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Mach with Kmotion USB controller
« Reply #1 on: February 20, 2008, 11:11:37 AM »
can't figure this out. One minute it says Mach isn't supported, then says it is with a plugin and then makes out like you don't need Mach at all anyway  ??? i.e. It says their gcode interpreter runs on a PC and sends motion control commands to their board (i.e. what do I need Mach for then?) but then says you need an "application" to do this - I just don't get what their stuff is meant to do and what else you need to make it do it.
Offline Tarak
  •  229 229
« Reply #2 on: February 22, 2008, 02:29:59 PM »
Yeah I think I'll stick with CNC TekniX and Mach.
www.cncteknix.com
Offline RossF
  •  31 31
« Reply #3 on: July 02, 2010, 04:04:53 AM »
I realise that I may be a little late in entering this debate but I have recently converted a milling machine and then, more recently, a lathe, using the Kanalog/Kflop boards with Mach3 and I couldn't be more please with the results.
I would not have started on the lathe if the milling machine had not been such a roaring success and the help and guidance from Tom Kerekes at Dynomotion was superb.
Ross Ferguson
