Hello Guest it is June 11, 2026, 06:03:24 AM
Author Topic: Brain makes mach3 hang up  (Read 14114 times)
« on: January 31, 2008, 02:02:32 AM »
Hi everyone, when i use internal variables as V0 bit1 as an "input", through nop, and then to an internal variable V1 bit 0 as an "output", it makes mach3 to hang up...
I'll want to use it like a truth table as inputs ( V0 bit 1 to 12 ) and then make a binary pattern in the V1 variable.
It's for a toolchanger project...
Why ???
Re: Brain makes mach3 hang up
« Reply #1 on: February 01, 2008, 07:39:45 AM »
There are some bugs in brains, Brian will get to fixing them after he stabilizes the core of Mach, last estimate I heard was 2-3 months before he can get to it.
In the Meantime, you might be better of by using "UserLEDs" as your bits to track changes.
scott
