Hello Guest it is June 09, 2026, 03:08:00 PM
Author Topic: Post for OneCNC Mill 3-5 axis, Lathe, and Wire EDM or foam  (Read 40232 times)
« on: January 04, 2008, 03:40:14 PM »
Here is the Post Processors I did for OneCNC there are 3 of them.
One for Mill XR2 with support for 4th and 5th axis
One for Lathe XR2
One for Wire XR2 EDM (or can be used for a foam cutter)
Re: Post for OneCNC Mill 3-5 axis, Lathe, and Wire EDM or foam
« Reply #1 on: December 31, 2008, 12:32:15 PM »
Does this post processor work with mill XR3?
« Reply #2 on: January 01, 2009, 08:48:42 PM »
Hey SD,
   I have not upgraded to X3 yet, BUT, I suspect it would since they work the same way.
If you want, ask "Rich Kahn" (tech support guy for OneCNC america, FL), he can define the differences for you if they are different.
Just try it out and see if it will post to mach3 and mach 3 run it.  Also, in OneCNC you can edit your on Post.
scott
