Hello Guest it is June 09, 2026, 11:03:25 AM
Author Topic: 3D polyuretane special cutter  (Read 15194 times)
« on: January 04, 2008, 02:48:42 PM »
Hi.
This is my newest work, and also the most demanding work that I ever done.
It is a 3 axis machine to cut large blocks of polyurethane with strips of wood. My client will use this machine primary to make surf blanks.
Some facts: around 30 rollers, 7Kw including vacuum pump and cleaner.
It is tested and working fine. We are only doing a cage around all the machine to maintain a safety perimeter.
It was all designed in my workshop, in south Portugal.
I am accepting orders  ;)
Re: 3D polyuretane special cutter
« Reply #1 on: January 04, 2008, 02:55:11 PM »
Pictures...
« Reply #2 on: January 04, 2008, 07:06:32 PM »
Good looking machine.  :)
« Reply #3 on: January 04, 2008, 11:19:43 PM »
GOOD looking job Filipe.
What are you using for a cutting blade ? (or is that proprietary ?)
It doesn't look like a regular bandsaw type.
Again, FINE WORK,
RC
« Reply #4 on: January 05, 2008, 01:13:06 AM »
The machines uses an abrasive wire. It passes through the material to cut at 250Km/h.
It have 3 of this wires, one one the exis that is shown on the first picture (horizontal) and the other two on the moving parts that are vertical.
Filipe
« Reply #5 on: January 05, 2008, 07:52:23 AM »
EXCELLENT !
Thanks Filipe !
RC
ynneb
« Reply #6 on: January 13, 2008, 02:12:50 AM »
A video showing it working would be great. You could add it here, http://www.youtube.com/groups_videos?name=artsoft and stream it into this thread.
