May 28, 2012, 11:20:45 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Can i get the state of coordinate system ?
Pages: 1   Go Down
Print
Author Topic: Can i get the state of coordinate system ?  (Read 963 times)
mechaniac
Active Member
Offline Offline
View Profile
« on: December 25, 2007, 07:09:10 AM »
Hello,
I'm trying to get the current state of coordinate system (e.g. G94, G95......etc.) in a macro. Is this possible, and how works the code?  Sorry for this possible stupid question, but I'm an absolutely Newbie in programming.
Thanks for answers.
Greetings,
Helmut
In theory, there is no difference between theory and practice. In practice there is.
Bodini
Active Member
Offline Offline
View Profile
« Reply #1 on: January 05, 2008, 12:20:19 PM »
So is your question "how do i get the current offset"?  Like G54, G55, G56, etc.?
If that IS the question, then I've deduced this much...
"GetVar (5220)" returns a single digit number.  This number is the same number as the offset on the "Offsets" screen in Mach.
So on that screen, G54=1, G55=2, G56=3, etc.
If you try the code below in the "VB script editor" (built into Mach, in the pull-down "Operator" menu), the number returned does indeed correspond with the "fixture" number :
FixNumb = GetVar (5220)
MsgBox (FixNumb)
Even if this wasn't your question, I learned something today.  Wink Smiley Tongue
-Nick
Bodini
Active Member
Offline Offline
View Profile
« Reply #2 on: January 05, 2008, 12:21:15 PM »
Oh yeah, I found that info here: http://www.machsupport.com/MachCustomizeWiki/index.php?title=Mach_specific_Subroutines/Functions_grouped_by_purpose#Access_to_the_machine_G-code_parameter_block
mechaniac
Active Member
Offline Offline
View Profile
« Reply #3 on: January 05, 2008, 02:18:42 PM »
Hi Nick,
Thank you, this will answer my question.
Greets,
Helmut
Pages: 1   Go Up
Print
Jump to:
