Hello Guest it is June 12, 2026, 04:26:48 AM
Author Topic: cancel feed rate over-ride in ATC macro  (Read 6956 times)
« on: December 18, 2007, 05:51:47 PM »
Festive greetings to everyone.
I have a tool change macro working on my router. I need to cancel the feed rate over ride at the beginning of the macro before it executes the first move of the sequence. I can not seem to get this to work. I have tried to use oem code 201 which is feed rate over ride off. Is this a suitable approach? Can you give me an idea how I reference this with script? I have not seen any macros where the feed rate over ride is cancelled. I would have thought that this is commonly done.
Thanks for your help. Russ.
Re: cancel feed rate over-ride in ATC macro
« Reply #1 on: December 18, 2007, 11:44:40 PM »
try OEM 1014, feedrate Reset.
« Reply #2 on: December 22, 2007, 12:34:45 PM »
That did it. Thanks very much for your help.
Russ.
