May 28, 2012, 11:17:20 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  VB and spindle
Pages: 1   Go Down
Print
Author Topic: VB and spindle  (Read 929 times)
Bit79
Active Member
Offline Offline
View Profile
« on: December 12, 2007, 07:27:06 AM »
I'm trying to realize some macros to manage better my cnc, but I find some difficult.
In particular in a VB macro I need to detect if the spindle is on or off, and execute the macro only if the spindle in off, or ignore it if the spindle is on, but I don't know which parameter I have to test. How can I do it?
Thank you!
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #1 on: December 12, 2007, 04:57:21 PM »
'spindle on check macro
Sub Main()
If GetOEMLED(116) then
Message("spindle is running cannot execute macro.")
Exit Sub
Else
****Put in the code for your macro here****
End If
End Sub
Main
'Scott
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
Bit79
Active Member
Offline Offline
View Profile
« Reply #2 on: December 13, 2007, 04:41:30 AM »
Thank you very much.
I tried and it work good.
I also tried with:
If GetOEMLED(11) then....
and It work likewise. What's the difference between GetOEMLED(11) and GetOEMLED(116)?
Pages: 1   Go Up
Print
Jump to:
