May 28, 2012, 11:13:42 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Tangent Corner
| |-+  Bargain Basement
| | |-+  touch probe/tool height setting probe
Pages: « 1 2 3 4 5 6 7 8 9 10 11 12 13 »   Go Down
Print
Author Topic: touch probe/tool height setting probe  (Read 37586 times)
zarzul
Active Member
Offline Offline
Wyoming, USA
View Profile
« Reply #110 on: September 02, 2010, 07:18:19 AM »
MODIFIED: 3/6/2011  DELETED REFERENCE TO A SITE
Bill,
  I also sell directly and can take you order, contact me at aminear@wyomingwireless.com
Arnie
« Last Edit: March 06, 2011, 05:57:29 AM by RICH » Logged
bfcg
Active Member
Offline Offline
View Profile
« Reply #111 on: September 02, 2010, 12:22:41 PM »
I guess I had a cerebral vapor lock when I gave them my email address with a typo. All is good now, thanks.
rcaffin
Active Member
Offline Offline
View Profile
« Reply #112 on: September 15, 2010, 12:19:24 AM »
Hi
Someone mentioned a company or web site with a name like IPStylus or similar that sells a replacement stylus.
But I cannot find it again.
Help please?
Bob La Londe
Active Member
Offline Offline
View Profile
« Reply #113 on: February 10, 2011, 11:06:46 AM »
I am interested in your touch probe.  Every modestly priced touch probe I have read about sticks eventually.
What have you done to reduce, cure, or eliminate sticking?
What size tips do you have for your probe, and what is your current price?
Is there any backlash or noticeable inherent error in the probe itself?
What kind of procedure does it require to get it setup?
Can your probe be used for edge finding or is it strictly a vertical probe?
ostie01
Active Member
Offline Offline
View Profile
« Reply #114 on: February 10, 2011, 12:39:49 PM »
Loot at the video, this is  an all direction probe.
http://www.youtube.com/watch?v=ytX1dvX3Tpg
Jeff
bfcg
Active Member
Offline Offline
View Profile
« Reply #115 on: February 10, 2011, 02:09:56 PM »
I think the probe is pretty accurate, accurate enough for the things that I do.
My problem is not with the probe but what you do with the point cloud data. I have beeen very slow at learning due to extreme time constraints.  I dabbled with some software and didn't really get anywhere.
I would love to see a demo on how to use the point cloud data in a reverse engineering way.
I know that it could be used directly to Mach as code but I need to get it out and edit it then create a tool path.
« Last Edit: February 10, 2011, 02:11:49 PM by bfcg » Logged
Bob La Londe
Active Member
Offline Offline
View Profile
« Reply #116 on: February 10, 2011, 02:37:02 PM »
http://www.micro-machine-shop.com/3D_digitizing.htm
Seems to have some good info.  Not point by point tutorial though.
diyengineer
Active Member
Offline Offline
View Profile
« Reply #117 on: May 15, 2012, 03:46:02 AM »
Any word on a replacement stylus for sale?
Everyones probe still holding up? Just got mine! Smiley
zarzul
Active Member
Offline Offline
Wyoming, USA
View Profile
« Reply #118 on: May 15, 2012, 05:50:28 PM »
I have been making these now for 5 years and have had great comments back from the users.
I use mine on a regular basis, mainly for finding the center of holes.
To order contact me at aminear@wyomingwireless.com
beware of knock-offs
diyengineer
Active Member
Offline Offline
View Profile
« Reply #119 on: May 15, 2012, 05:55:54 PM »
Do you supply cnc4pc.com? That is where i purchased mine from.
for replacement parts and stylus's i will shoot you an email. Can't wait to test it out!
Do you suggest any software that can take the points and turn the points into anything usable? Surface, solid, etc.
Pages: « 1 2 3 4 5 6 7 8 9 10 11 12 13 »   Go Up
Print
Jump to:
