Hello Guest it is June 09, 2026, 01:13:59 AM
Author Topic: Need help changing Mach labels or font size. Please.  (Read 57432 times)
« on: November 23, 2007, 10:26:02 AM »
Hello,
Does anyone know how to change the font size on the Mach 3 screens? I'm using XP.  I've been to the font menu under the config menu but I can't make the changes stick??  Several of the labels in the main screen and most of the wizards are cut off.  Thanks.
Re: Need help changing Mach labels or font size. Please.
« Reply #1 on: December 22, 2007, 07:48:25 AM »
I just put the licensed version on my CNC computer last night. I have the same problem, my labels are cut off both length and height wise. I can read most of them, but I still would like to fix it. Using the Fonts on the text menu, I change the size and type of the font, but when I close the screen it does not stay.
I also noticed in my Thread Mill wizard, when I enter numbers, as soon as I go to the next field the numbers change back.
I have double checked on the about tab and it shows my name in the Licensed To window.
Could anyone shed some light on what I may be doing incorrectly?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: December 24, 2007, 04:29:48 AM »
When ever you enter a number in a DRO you have to press ENTER to confirm it.
Have you got auto scaling of screen set in the general config, this can some times mess the fonts up.
Graham.
« Reply #3 on: December 24, 2007, 06:16:36 AM »
Before closing Mach, go to operator, save current layout.
« Reply #4 on: December 24, 2007, 09:53:36 PM »
Thanks, Brian helped with the DRO. I did go and set the auto scaling and that fixed the cutoff labels.
Thanks for the help.
