Hello Guest it is June 11, 2026, 04:28:01 PM
Author Topic: Rectangular wizard-inside climb doesn't-bug?  (Read 86064 times)
Offline Bloy
  •  158 158
« on: April 15, 2006, 08:25:01 AM »
Rectangular wizard cuts conventionally when asking for climb of inside rectangle.
Am I missing some setting?  I ask for an inside rectangle, set it to climb, but it always cuts conventionally.
 John Prentiss brought this up in the Yahoo group but apparently it got lost in all the posts.
Is this a real bug or is there something else in Mach3 to have the climb selection function properly?
John (bloy)
Re: Rectangular wizard-inside climb doesn't-bug?
« Reply #1 on: April 15, 2006, 03:39:23 PM »
Okay I will have a look at it  ;D If it is a bug i will have it fixed in a few hours..
www.newfangledsolutions.com
www.machsupport.com
Offline Bloy
  •  158 158
« Reply #2 on: April 16, 2006, 09:18:31 AM »
Hi Brian,
  ...just a follow-up.
  Did you find anything in the inside rectangular climb-cut ?
Many Thanks,
  John(bloy)
« Reply #3 on: April 16, 2006, 10:55:52 AM »
I am looking at it now... I was in the middle of Gerber importing code for LCam Pro, but I now have that all working and will start in on the wizard set.
Thank you
Brian
www.machsupport.com
« Reply #4 on: April 16, 2006, 02:26:55 PM »
It is fixed and off to Art to be added into the release
Thank you
Brian
www.machsupport.com
Offline Bloy
  •  158 158
« Reply #5 on: April 16, 2006, 08:53:37 PM »
Many MORE Thanks, Brain!
