Hello Guest it is June 09, 2026, 09:14:02 PM
Author Topic: Accel / Decel  (Read 7986 times)
Accel / Decel
« on: November 17, 2007, 05:25:14 PM »
Hello all,
  I'm new to CNC so please bear with me. (thanks already)
When I get my lathe done I plan to retrofit a small surface grinder/slicing machine.
My question is:
      If the table, which is relatively heavy, is driven by a rack and pinion, how does Mach control the acceleration and deceleration as to not overtravel and force steps on the motor ?
     Is this done automatically by Mach through tuning... or is there a procedure when writing the code ?
Some servo motors have an automatic tuning sequence that they perform on their own to determine the inertial loads and set the accel / decel accordingly.
  My bigger grinder has a hydraulic table but the small one will be either a rack and pinion or a clamped timing belt with stepper.
All help is GOOD help !
THANKS
Re: Accel / Decel
« Reply #1 on: November 17, 2007, 05:32:43 PM »
Yes, accel and velocity are done on the motor tuning page.
Re: Accel / Decel
« Reply #2 on: November 17, 2007, 05:38:37 PM »
PERFECT ! !
Thanks Hood
With all of this help... I'll be a PRO in no time.
Thanks to ALL
