Hello Guest it is June 09, 2026, 07:40:47 PM
Author Topic: Problem with MACH3 Mill  (Read 7346 times)
« on: November 16, 2007, 12:47:08 AM »
Hi
I am using MACH3 for hobby cnc stepper motor application.
Since last time i find problem with MACH mill like i can run motor in only forward direction when use reverse direction key then only DRO is updating but motor is not moving.
Could you please advice,
Regards
Manoj
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Problem with MACH3 Mill
« Reply #1 on: November 16, 2007, 02:09:37 AM »
Hi, Manoj
In config, ports & pins, motor outputs, change the "Direction Active Low" to opposite State.
If your motors run backwards, Config, Home & limits, Change the "Reversed", State.
Hope this Helps, Chip
