Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 11:06:01 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
General CNC Chat
Show"N"Tell ( Your Machines)
4th Axis for CNC Router
Pages:
1
Go Down
« previous
next »
Author
Topic: 4th Axis for CNC Router (Read 3367 times)
Haik
Active Member
Offline
Haik
on:
November 13, 2007, 04:29:34 AM »
Here's a 4th axis I built from a 6 inch rotary table and a high-torque NEMA 34. The rotary mount is fixed to and MDF bed and the tailstock slides to accommodate the workpiece. The whole unit bolts down to the table of my CNC Router. A Gecko G203V (Vampire) drive quick connects to the NEMA 34 and safely disconnects when not in use (don't try this with other drives... it'll burn them out!). A Perske 24k rpm spindle (on a VFD) holds the tool. I use either a laser or dial-indicator to true to gantry, that usually takes about 5 minutes.
This setup works great and I can cut using full numerical rotations or via indexing.
-Haik
Glenn
Active Member
Offline
Re: 4th Axis for CNC Router
Reply #1 on:
September 16, 2009, 05:36:42 PM »
Hi Haik,
I noticed your build on this forum, and would like to build one like this; Would a rotary table like this be a good place to start, or how much backlash and slop is in one of these cheap tables?
http://cgi.ebay.com/4-ROTARY-TABLE-PRECISION-GROUND-FOR-MACHINIST-NEW_W0QQitemZ190335313338QQcmdZViewItemQQptZBI_Tool_Work_Holding?hash=item2c50de65ba&_trksid=p3286.c0.m14
Thanks for any replies,
Glenn
Don't assume anything.....it'll make a Manager out of U and Me!
gfroe123
Active Member
Offline
Reply #2 on:
November 16, 2009, 09:02:38 PM »
I found a place on the web called the Little Machine Shop. The rotary table boasts a 10 second backlash. I see this as .5 degree. This is OK as long for some applications if you keep the rotation one way. If you are willing to spend a little more the Sherline is the way to go. Good luck
Overloaded
Global Moderator
Offline
Reply #3 on:
November 16, 2009, 09:35:15 PM »
10 second = 0.002 777 777 777 8 degree
.5 degrees = 30 minutes or 1800 seconds
RC
"I haven't failed. I've just found 10,000 ways that won't work." Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Global Moderator
Offline
Reply #4 on:
November 16, 2009, 10:54:51 PM »
Hmm.....
You never know until you try one. My Sherline rotary table has 5 minutes of backlash.
So at 1" from the center the backlash is equal to 1/2 the thickness of a hair on your head.
Now it all depends a little on what your trying to do. Linear to angular conversion :
1 minute = .0003" per inch or .0009" in 3"
1 arc sec= .000005" per inch
So 10 arc sec= .00005" backlash at 1" distance Or if you had a piece out at 3" that's .00015" at 3" distance.
I don't think your machine can machine to that.
So there is backlash and there is position. Now do you think for $99 you are going to get backlash equal to that?
Then you can also ask what is the positioning accuracy you are after?
Being practical about it all, the table may be perfectly fine for what you want to do.
Now i do have a positioning rotary table, that position wise, it's repeatable to 3 arc seconds. And if you bought it new it would be around $5000. That's not too much better than 10 arc seconds. Then of course, how would the average joe measureing it to find out!
Just some things for you to think about,
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
