May 28, 2012, 11:05:43 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Mach3 and G-Rex
| | |-+  Upload firmaware
Pages: 1   Go Down
Print
Author Topic: Upload firmaware  (Read 1787 times)
lordyan
Active Member
Offline Offline
View Profile
« on: April 13, 2006, 02:37:27 AM »
Hello,
First excuse me for my bad English.
I have a G-rex with gecko motion firmware.
When I connect the G-rex to my computer with crossover cable, it looks like if i have no cable connected.
The result of ipconfig /all : not connected.
I try with standard cable with router/switch and it is the same.
Someone can help me?
Thanks.
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #1 on: April 13, 2006, 06:51:41 PM »
Can you set a static IP on your computer and try that?
Fixing problems one post at a time Wink
www.newfangledsolutions.com
www.machsupport.com
lordyan
Active Member
Offline Offline
View Profile
« Reply #2 on: April 18, 2006, 02:55:49 AM »
Hello,
I try to define a static IP, but it is the same.
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #3 on: April 18, 2006, 05:53:14 PM »
I have to let mine set for about 20 Sec then I can hook up to it... How long do you let it set for?
www.machsupport.com
ART
Administrator
Offline Offline
Tough as soggy paper.
View Profile
« Reply #4 on: April 24, 2006, 09:38:03 PM »
 Geckomotion formware will not talk via tcp , I believe it is for USB only, and not with MAchIV..
Art
ART
Administrator
Offline Offline
View Profile
« Reply #5 on: April 24, 2006, 09:38:53 PM »
Sorry, hit reply too quick. If you have the geckomotion loaded, you need to reflash it with MachIV firmware to see it on TCP from Gloader I think..
Art
Pages: 1   Go Up
Print
Jump to:
