Hello Guest it is June 09, 2026, 09:47:59 PM
Author Topic: Welcome to the dspMC/IP board  (Read 256168 times)
Re: Welcome to the dspMC/IP board
« Reply #40 on: December 23, 2008, 09:59:17 AM »
The latest version is on the web page www.vitalsystem.com/dspmc.  The above AxisWorks is one of the alpha versions that was buggy.  It was not released for general use.
You do enter PID settings in a separate window.  you don't have to close it while you work with the graph.  leave it open so you can re-enter values and see result in the graph.
Will be updating the manual soon for the latest AxisWork operation.
thanks
Rufi
« Reply #41 on: December 23, 2008, 10:27:13 AM »
Leaving the window open is fine, however, im running a 17" monitor, and its not possible to get a full view of both windows, also, when you use the graph it pretty well blocks everything. The version posted above looks more more user friendly. It looks similar to the Baldor Workbench i used to tune my drives, much nicer to tune with IMO.
« Reply #42 on: December 23, 2008, 11:45:36 AM »
thanks for the feedback.  the graph window is small on the above version.  is that ok?  we will try to put similar features in the new version.
regards,
Rufi
