May 28, 2012, 12:31:10 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  running batch files in VB
Pages: 1   Go Down
Print
Author Topic: running batch files in VB  (Read 1396 times)
buck
Active Member
Offline Offline
View Profile
« on: November 03, 2007, 01:08:45 AM »
I am attempting to integrate the controls of my Canon PowerShot S70 into a Mach3 program. Before I continue, I should mention that I know very little about cnc, software, and electronics, in general. That being said, my theory for solving the above problem is this:
Write an M-code that runs a batch file that, in turn, activates/controls the shutter release on my camera.
Does anyone have any advice on this concept or the approach I am proposing?
buck
Am I in fantasy land?
vmax549
Guest
« Reply #1 on: April 01, 2008, 11:27:43 AM »
I f you are refering to a Mcode were mach goes outside and runs a dos batchfile to active your camera then yes. We do the same thing to print the tool table data to a printer from inside of mach.
If you are refering to be able to talk to your camera directly then maybe. Depends on the COM protocal
stirling
Global Moderator
Offline Offline
UK
View Profile WWW
« Reply #2 on: April 02, 2008, 04:37:32 AM »
If you can operate your S70 from DOS, then yes you can do this the way you've siggested. However I have an S50 and although I know how to remotely operate it from the windoze app supplied with the camera, I wasn't aware that you could do it from DOS. Tips would be appreciated. It's a shame that a windoze API isn't shipped with these things!
Pages: 1   Go Up
Print
Jump to:
