Hello Guest it is June 11, 2026, 08:01:57 AM
Author Topic: running batch files in VB  (Read 8414 times)
« on: November 03, 2007, 01:08:45 AM »
I am attempting to integrate the controls of my Canon PowerShot S70 into a Mach3 program. Before I continue, I should mention that I know very little about cnc, software, and electronics, in general. That being said, my theory for solving the above problem is this:
Write an M-code that runs a batch file that, in turn, activates/controls the shutter release on my camera.
Does anyone have any advice on this concept or the approach I am proposing?
buck
Am I in fantasy land?
vmax549
Re: running batch files in VB
« Reply #1 on: April 01, 2008, 11:27:43 AM »
I f you are refering to a Mcode were mach goes outside and runs a dos batchfile to active your camera then yes. We do the same thing to print the tool table data to a printer from inside of mach.
If you are refering to be able to talk to your camera directly then maybe. Depends on the COM protocal
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #2 on: April 02, 2008, 04:37:32 AM »
If you can operate your S70 from DOS, then yes you can do this the way you've siggested. However I have an S50 and although I know how to remotely operate it from the windoze app supplied with the camera, I wasn't aware that you could do it from DOS. Tips would be appreciated. It's a shame that a windoze API isn't shipped with these things!
