Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 12:25:44 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Newfangled Solutions Wizards
(Moderator:
Ron Ginger
V2.75 ready for test
Pages:
1
2
3
Go Down
« previous
next »
Author
Topic: V2.75 ready for test (Read 5840 times)
Ron Ginger
Active Member
Offline
Re: V2.75 ready for test
Reply #20 on:
October 30, 2007, 10:28:46 AM »
Its on Newfangled, but the link is still broken. Here is a direct URL that will work.
http://www.newfangledsolutions.com/downloads/Manual-V2-75.pdf
vmax549
Guest
Reply #21 on:
October 30, 2007, 09:07:43 PM »
Hi ROn good job. Just a couple of highlites to consider.
Page 14 Start Position Button should read as "XY reference position" same with screenpage.
Page16/17 Start angle decription should read the same as page 11 start angle description
Operational:
Cut circle grooving does not appear to cut correctly it appears to be using a lead in arc instead of inline feed. Only simulated did not actually cut it but both the circle and groove produce identical code in simulation???
Thread milling an inside thread SHOULD cut from bottom to top not top to bottom. If you cut from top to bottom you are driving the mill INTO the chip load not away from it. Good way to break small expensive thread mills.
Would be nice to include the G84 threading function in wizards that have drill patterns. Half of the holes we drill are threaded. Contrary to popular belief Mach does an excellant job with SR tapping using the G95/Gg84 tapping cycle.
Wizards do a good job if you are just one offing programs but without being able to SET top of material height it is pretty much handicapped from producing usefull full program code.
Just some thoughts, (;-) TP
vmax549
Guest
Reply #22 on:
October 30, 2007, 09:55:09 PM »
Ron you might want to check the thread milling wizard it looks like the inside and outside processes are swapped.
Also there appears to be a lead in problem with what should be the inside process. It gouges down thru the thread then moves in and starts the helix upward.
vmax549
Guest
Reply #23 on:
October 31, 2007, 01:38:41 PM »
Ron if you need any help just holler. I can build screens and modify JPGs if needed. I could also update the MACH help file system so when you right click on the item it brings up the help wizard. I have mine set to speak the file also. I notice most of the NFW functions are empty in the help file.
Ron Ginger
Active Member
Offline
Reply #24 on:
October 31, 2007, 04:38:22 PM »
I just updated the wizard in reply 1 of this topic. I found a bug in the surface wizard that was not handling the top of material correctly- it actually dives into the work and tries to cut the last pass first. Not good !
Cruiser
Active Member
Offline
Reply #25 on:
November 04, 2007, 07:21:49 PM »
Mach is real good at telling us a problem is in line number such & such, so then i count 1 2 3 4 . . . .. ..347 348 ! can we get a button for number / renumber ?
CRUISER
Don
vmax549
Guest
Reply #26 on:
November 05, 2007, 02:21:02 PM »
Hi RON, did you get a chance to check out the thread milling wizard yet?
scottdunbar
Active Member
Offline
Reply #27 on:
January 13, 2008, 07:05:43 PM »
Hi Ron,
Will you be fixing the circular groove problem soon?
Scott
Ron Ginger
Active Member
Offline
Reply #28 on:
January 13, 2008, 09:47:25 PM »
I just today did a major re-write of the thread milling wizard, and I think its now correct. Ive sent it off to Brian to put in the Mach kit.
I also corrected the tool table screen, it now includes the description field, and correctly handles metric tool parameters.
I have not worked on the circular groove yet. I will try to get to it tomorrow.
Pages:
1
2
3
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
