Hello Guest it is June 11, 2026, 12:11:57 PM
Author Topic: Mach3 turn not showing tool number  (Read 8034 times)
Offline mick
  •  60 60
« on: October 14, 2007, 09:07:04 AM »
Hello everyone,
                     i have been trying to write a little vb script ,but the tool number is not displayed,the gcode stops and waits
at M6 Txx for cyclestart.
                       using :   tool= getselectedtool()    allways shows zero.
This is not so in Mach3 mill.
HELP please.                           thanks
                                                      mick.
Offline drew
  •  79 79
Re: Mach3 turn not showing tool number
« Reply #1 on: October 14, 2007, 10:49:35 AM »
For turn use 'tXXYY' where XX tool number, YY offset number for example "t0101" no M6 needed.
To set the tool number DRO use VB function  "SetCurrentTool(tool)" where var. 'tool' is the selected tool.
If you dont want mach to stop for a tool change there are options for that in the configure menu.
  Drew
If I had something important to say it would be here.
Offline mick
  •  60 60
« Reply #2 on: October 14, 2007, 11:59:45 AM »
drew,
           many thanks for that I,m up and running again.
        mick.
