May 28, 2012, 12:23:47 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Brains Development
| | |-+  Available hardware for TCP Modbus?
Pages: 1   Go Down
Print
Author Topic: Available hardware for TCP Modbus?  (Read 3212 times)
mannby
Active Member
Offline Offline
View Profile
« on: October 09, 2007, 08:18:16 AM »
Hello All, what hardware I/O-board or PLC for TCP or Serial Modbus is available and
where could I buy it? I was watching the new videos about Brains and Modbus
and I want to try it.
Regards
Roger
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #1 on: October 09, 2007, 10:17:55 AM »
I think it is Peter Homan that has the MOD I/O board. PLCs, lots to choose from. Automation direct is a good place to start looking for those. Look at the DL06. There are lots of options, these are just a couple.
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
mannby
Active Member
Offline Offline
View Profile
« Reply #2 on: October 09, 2007, 01:51:16 PM »
Thanks Brett,
So it should be possible to use Homann MC-01 Mod I/O with the Brain instead of writing
macro pumps and if I don't need the plc functions in for example DL06?
Roger
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #3 on: October 09, 2007, 02:13:44 PM »
I think that is correct Roger, better let someone else comfirm this before you order the board though.
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #4 on: October 09, 2007, 03:47:11 PM »
I just got a Ethernet module working with TCP modbus and automation direct PLC.
Scott
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #5 on: October 09, 2007, 04:56:40 PM »
 Smiley Good job Scott. You got a part number or a link to that Ethernet module?
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #6 on: October 09, 2007, 05:40:39 PM »
H0-ECOM-100
is the name of the module, I recommend getting the manual that goes with it, and also upgrade to the latest release of Net3, and Directsoft5 from Host Engineering.
Remember also, to use a cross over cable if going direct from Pc to PLC, if you use patch you will have to have a hub/switch.
scott
Peter Homann
ModIO Adviser
Active Member
Offline Offline
View Profile WWW
« Reply #7 on: January 11, 2008, 12:51:42 AM »
Thanks Brett,
Roger
Hi Roger,
The ModIO will work fine being driven via Brains. Should be no different than from MacroPumps, other than the different representation of the brains and the functionality they offer.
http://homanndesigns.com/store/index.php?main_page=product_info&cPath=2&products_id=4
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com/store
email: peter at homanndesigns.com
mannby
Active Member
Offline Offline
View Profile
« Reply #8 on: January 11, 2008, 11:44:16 AM »
Thanks Peter,
I have bought a couple of ModIO from Homann but haven't come around to try them yet.
It's never enought time.  Smiley
Regards
Roger
Pages: 1   Go Up
Print
Jump to:
