Hello Guest it is June 12, 2026, 08:51:43 PM
Author Topic: Mach3Turn  (Read 20202 times)
Offline zarzul
  •  233 233
  • Wyoming, USA
Re: Mach3Turn
« Reply #10 on: September 28, 2007, 11:05:01 AM »
I think the only thing wrong is you don't go to view, you go to wizards and they should show up there.
you need to put them in a new folder under mach3\turnaddons\my turn
put the turning.set and turning.set.def here
Then make a subfolder in the folder my turn, called bitmaps, this is where the bitmaps are put.
Then when you run mach3 don't use view, just go to wizards and it will show up in the list there.
Re: Mach3Turn
« Reply #11 on: September 28, 2007, 12:49:31 PM »
Arnie
Yes I have put the files in the places you recommend, but I have lost the Turn screen If I go to Veiw/load screens I can get mill screen, but can't find turn screen.
Mike
Offline zarzul
  •  233 233
  • Wyoming, USA
Re: Mach3Turn
« Reply #12 on: September 28, 2007, 02:28:01 PM »
Mike,
When you go to load screens, select the file types as turn sets   they have the file extension of lathe.lset or 1024.lset
Are you seeing the wizard from the wizard menu selection?
Arnie
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Mach3Turn
« Reply #13 on: September 29, 2007, 12:03:48 AM »
Hi, Mike
A picture is worth how much ?
Hope this Helps, Chip
Re: Mach3Turn
« Reply #14 on: September 29, 2007, 04:43:48 AM »
Arnie & Chip
All sorted, I seem to have a different version, as the lathe file is an red flash with yellow M3 icon marked 1024 and no extension, which is very confusing as mill & plasma have usual icons !
However the extra wizards are now in the menu,am sure will be usefull
Thanks for help
Mike
