Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 12:19:57 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
CANNED G77/G78 LATHE CYCLE HELP??
Pages:
1
Go Down
« previous
next »
Author
Topic: CANNED G77/G78 LATHE CYCLE HELP?? (Read 2056 times)
backyardcnc
Active Member
Offline
on:
September 23, 2007, 03:46:36 PM »
Does anyone have any info on using the canned cycle G77/G78 in MACH3TURN? There is no real info in the MACH DOCS and I am specifically seeking info on what parameter inputs are supported by these macro's. I have tried reading the macro files themselves but I am no programmer and cannot for sure decide what it all means
Appreciate any comments
Gerald
Brian Barker
Administrator
Offline
Re: CANNED G77/G78 LATHE CYCLE HELP??
Reply #1 on:
September 25, 2007, 07:38:20 AM »
It has been years since the last time I looked at that code
It would take me about an hour to get you the info for the "stock" can cycles... I would just play with it and see how it works at this point... I will see if I can find the time to look at the macro.
Brian
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Brian Barker
Administrator
Offline
Reply #2 on:
September 25, 2007, 07:41:22 AM »
After looking at the macro I can see that I put in the data to show you how to use the Macro's
' G77
'(Xx.*********x XDia NEEDED)
'(Zx.*********x End Z NEEDED)
'(Fx.*********x Feedrate)
'(can be Set In the settings page: 'Hx.*********x Depth of cut)
'(Cx.*********x Clearance In the X)
'(Qx.*********x Clearance In the Z)
'(Kx.*********x ZStartpoint)
'(Rx.*********x XStartpoint)
'(Tx.*********x Taper In Deg)
'G78
Hope that helps
Brian
www.machsupport.com
backyardcnc
Active Member
Offline
Reply #3 on:
September 25, 2007, 01:38:38 PM »
Thanks Brian,
I had found this info looking in the macro but after much playing with the macro g77 I just can't get it to do what I think it should do using the parameters as labelled
for example I would expect the following code to turn an outside diameter: 2" in length to .5" in diameter starting with .75" stock and do that in .010 cuts allowing .1 clearance in X and .050 clearance in Z on the retracts with Z 0.0 at the end of the stock away from the chuck and the controller in diamter mode:
G77 X0.5 Z-2.0 F0.5 H0.01 C0.1 Q0.05 K0.0 R0.75 T0.0
It just doesn't do that so I guess I either am either blind or stupid or the macro doesn't work because I have tried all different combinations of settings to achieve this but just can't make it happen as I feel it should and that is is turn the diameter towards the chuck from a diameter of .75 down to .5 for a length of 2 inches (ie z=0.0 to -2.0).
Oh well I will keep pluggin I guess or try to find a book on VB to write my own macros to acheive something more like a g71/g70 in FANUC for turning profiles. Can you point me in the right direction as far as writing macro's goes? Am I looking for standard Visual Basic programming info?
Gerald
amtech
Active Member
Offline
Reply #4 on:
August 05, 2008, 05:30:47 AM »
Anyone got G77 or M1077 to work? Is it something that only works in a full version of Mach?
It would seem that the most common thing you'll want to do is to reduce the diameter of your stock- without having to write multiple lines of G01!
G78 seems to work ok.
Note... not a complaint, Mach3 is great! I just want to be sure that I should persevere with G77!
Andy
Andy
Development Engineer
Amtech Electronics Ltd
Active Member
Offline
Carnoustie, Scotland
Reply #5 on:
August 05, 2008, 07:17:11 AM »
I know Brian is going to be doing a lot of work on Turn shortly so all of the things that are not quite right in Turn will be getting looked at.
In the mean time you could use one of the wizards to do your basic turning, facing and boring.
amtech
Active Member
Offline
Reply #6 on:
August 06, 2008, 05:48:57 AM »
I've looked at M1077, and found that theres a problem (in my case anyway) with tapers of 0 (ie, reduce the diameter of stock). I've 'fixed' the code and that now works. Tapers seem to work (haven't checked the angle calcs) but the Tx.x parameter is being interpreted as a toolchange instruction...?!
In ports and pins/turn options you can set cut depths etc so in its' most basic form you'll just do a touch-cut on your stock, set the part-zero, then G77 Xx.x Zx.x where X and Z are the final diameter and length of cut. The macro figures out how many passes to make based on your turn settings.
Here's the modified macro if it's of any use. Take out the 'andy' in the filename. As always, remember to take a copy of your original M1077 first!
M1077_andy.m1s
(4.42 KB - downloaded 154 times.)
Andy
BR549
Active Member
Offline
Reply #7 on:
May 24, 2010, 06:45:41 PM »
Last Edit: May 24, 2010, 06:51:59 PM by BR549
Jim_colo
Active Member
Offline
Reply #8 on:
January 08, 2012, 01:53:18 PM »
WOW! looks like a old post. Only have one question why is the G77 asking for a tool change?
I too added the M1077_andy.m1s with better luck. thank you Andy. The wizard adds too many lines of code!
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
