Welcome, Guest. Please login or register.
Did you miss your activation email?
December 02, 2008, 02:25:37 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Tangent Corner
| |-+  Bargain Basement
| | |-+  3 Ametek DC servo motors NEW
Pages: 1   Go Down
Print
Author Topic: 3 Ametek DC servo motors NEW  (Read 833 times)
DennisCNC
Active Member
Online Online
View Profile
« on: September 23, 2007, 02:06:32 PM »
I have three Ametek DC brush motors with the info bellow:
    *  Voltage 38 VDC
    * Torque Constant 44oz-in/amp
    * Amperage 0.2 Amps (no load)
    * Max Current 12 Amps
    * Speed 1,150 RPM (no load)
    * Rotation Reversible
    * Mount 4 tapped holes in face on   3-1/4" square pattern
    * Shaft 5/8" dia. x 1-1/4" smooth
    * Rear shaft 3/16" dia. x 3/8" at rear
    * Size 4" dia. x 4-1/2"
    * Weight  7 lbs.
Price $189 obo for three motors.
More info of a similar motor can be found here:
http://www.lowcostcncretrofits.com/servo%20motors.html
« Last Edit: September 25, 2007, 05:25:36 PM by ynneb » Logged
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
