Hello Guest it is June 12, 2026, 12:10:01 PM
Author Topic: HELP please Mach3 won't run my board  (Read 19531 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: HELP please Mach3 won't run my board
« Reply #10 on: September 29, 2007, 08:08:06 PM »
Hi, Maxmyo
Give this a try, Change the Dir/Steps Low Actives around.
Also have you tried the other Printer port address for Port #1, Other than std. 0x378, Tried 0x278.
Look at your other cnc program that works, Maybe it is using a different address.
Chip
« Last Edit: September 30, 2007, 12:15:40 AM by afn09556 »
« Reply #11 on: September 30, 2007, 05:11:16 AM »
Sorry for not replying :(
 Had a look at the xml and first look it seems fine as far as setup is concerned, but have a look at your Steps Per Unit  as they could be on the low side. Are these drives microstepping, half step or full step? What is the TPI of your ballscrew/leadscrew?
What Ron is meaning is go to Config menu then down to motor tuning. Use the sliders to increase/decrease your values for each motor and test by using the Up/Down arrows. Once you have the tuning the way you want then save the axis settings and move onto the next.
« Reply #12 on: September 30, 2007, 05:29:30 AM »
Try to activate the "Gecko half step mode" option on the Config->motor and pins tab
