Hello Guest it is June 09, 2026, 03:07:58 PM
Author Topic: Mastercam 9 & 10X Mach 3 Postprocessor  (Read 65321 times)
« on: September 09, 2007, 07:46:50 AM »
Hi guys
i found this mach3 postprocessor for mastercam 9 and i converted it to the mastercam x format through the mastercam software which it allows you to do so and here it is:
Mastercam 9 format: http://cnc.novalab.org/files/MACH3B_for_MC9.zip
Mastercam X format is attached
It supports 3 or 4 axis machines!
Hope you find it useful!
Ryanstewart86
Re: Mastercam 9 & 10X Mach 3 Postprocessor
« Reply #1 on: May 09, 2008, 11:10:09 AM »
Thankyou very much!!!
Tiwanacote!
« Reply #2 on: October 07, 2008, 09:57:24 AM »
Gracias por su aporte, en espera de poder ser util a ustedes.
« Reply #3 on: October 07, 2008, 10:07:05 AM »
Saludos encontre un driver paso direccion y trabaja bien con Mach3 y los datos son los siguientes: SERVOPACK  YASKAWA-onronAC IMPUTMODEL SJDE-08 APA-0Y1 PH 200-220 v-50-60 HZ  8.9 A AC-OUTPUTĀ· PH. 0 230V- 0 300 HZ3.7A-750 W todo hecho en CHINA
« Reply #4 on: August 08, 2009, 10:41:02 AM »
I have been using this post with MC9 for years works great is there a way to remove the () in MC's toolpath manual entry EX:
(G91 A60.0 F50.0)
(G90)
« Reply #5 on: September 21, 2009, 09:18:17 AM »
Hello Sir,
     How can I insert this post file to Matser Cam 10. Please give me instruction. I found some post file for MasterCam 10. This will come with other MMD file and control file including pst file. Please.....
High Tech Key
« Reply #6 on: September 29, 2011, 10:15:00 PM »
Thank Kyou..
 sir...
