Hello Guest it is June 09, 2026, 10:30:53 AM
Author Topic: Need help configuring G-Rex pins in Mach3  (Read 12673 times)
« on: September 09, 2007, 12:04:09 AM »
Can't find instructions for configuring the pin's for G-Rex.
Can someone direct me to where the info is?
Bill
Re: Need help configuring G-Rex pins in Mach3
« Reply #1 on: September 09, 2007, 05:19:22 AM »
Several threads in this board about it. I will loook for you this evening and try to help if your not sorted by then.
« Last Edit: September 09, 2007, 05:27:24 AM by Chaoticone »
« Reply #2 on: September 09, 2007, 11:39:42 AM »
Thanks Brett.
Anything you can find would be a big help.
Bill
« Reply #3 on: September 09, 2007, 07:31:29 PM »
Hey Bill, sorry, I just got in from work. All inputs and outputs are set to port 1, pins are: 1-16 ins and outs are 1-16 on the g100 ins and outs. Your Home switches should be wired to the ones marked LIM for each axis. They are inputs 17-22, 17=x, 18=Y, 19=Z, 20=A, 21=B, 22=C.
« Reply #4 on: September 09, 2007, 09:12:59 PM »
Thanks for the info Brett.
It's just what I needed.
Bill
