Hello
Guest
it is
June 10, 2026, 02:53:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
change spindle speed (eg. laser power) depending on velocity
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: change spindle speed (eg. laser power) depending on velocity (Read 7783 times)
vco-systems
1
on:
August 31, 2007, 06:08:17 AM »
I know that its possible to make the "spindle speed" constroll the power of a laser for an laser engraver, but is there any way to make the software compensate for change in velocity when cutting for example corners.
Brian Barker
3,860
Re: change spindle speed (eg. laser power) depending on velocity
Reply #1 on:
September 10, 2007, 11:35:55 AM »
That should be under ports and pins Spindle settings... that is what the Lazer option for the spindle should do ...
thanks
Brian
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
