May 28, 2012, 12:14:05 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Mach3 and G-Rex
| | |-+  Latest G100 Set-Up Guide
Pages: 1   Go Down
Print
Author Topic: Latest G100 Set-Up Guide  (Read 6322 times)
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« on: August 16, 2007, 07:34:22 AM »
I welcome input from other members.
« Last Edit: September 21, 2007, 10:00:09 PM by Chaoticone » Logged
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #1 on: September 21, 2007, 09:17:20 PM »
You can download the latest copy here. I welcome input from other members. I won't be posting the actual file any more, only a link. This is the best way I know to insure that you will be getting the latest copy.
http://www.machsupport.com/Downloads/machdownloads/G100_Set_Up_Guide_Rev.1_9-19-07.pdf
« Last Edit: November 04, 2007, 04:05:38 PM by Chaoticone » Logged
NewB
Holding
Offline Offline
View Profile
« Reply #2 on: November 04, 2007, 01:34:52 PM »
Please check the link. It ain't right.
NewB
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #3 on: November 04, 2007, 04:07:34 PM »
You are right, I fixed it.  Smiley  It must have gotten changed in the server swap.
bicycleboy
Active Member
Offline Offline
View Profile
« Reply #4 on: February 03, 2008, 01:11:14 AM »
Thanks for the guide.  It REALLY helped!
A major omission though.  With windowsXp you must either turn off the firewall for your local net or better yet add mach3 and gRexloader to the exempted applications.
I just had fun trying to figure out why on two nearly identical computers, one worked completely and the other couldn't run gRexloader or Mach3 but could be pinged, and amazingly successfully loaded with firmware and fpga code from IE using the IP address.  The G100 was setup about 9 months ago on the first computer and still worked.
I had seen a post about the firewall but the firest machine worked fine with it enabled.  Both computers had the firewall enabled with the same port and application exceptions on both so I didn't think the firewall was the problem.  gRexloader and Mach3 could never connect to the g100.  As soon as I disabled the firewall it worked.  Adding gRexLoader and Mach3 to the exceptions and enabling the firewall also worked.
I can only figure that some of the windoz updates that have been installed in the last 9 months somehow allowed the existing setup to work but when I built the new system the firewall had to be configured more strictly.  Hope this helps someone.
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #5 on: February 03, 2008, 08:22:37 AM »
Thanks for the info.
rasta
Active Member
Offline Offline
View Profile
« Reply #6 on: March 31, 2009, 06:00:16 AM »
Sorry but I can't get the link working , can you please re-post?
thanks
 mariano
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #7 on: March 31, 2009, 06:38:10 PM »
http://www.machsupport.com/docs/G100_Set_Up_Guide_Rev.1_9-19-07.pdf
Pages: 1   Go Up
Print
Jump to:
