Hello Guest it is June 10, 2026, 04:45:11 AM
Author Topic: G100 A/d inputs  (Read 7777 times)
G100 A/d inputs
« on: August 06, 2007, 07:22:35 PM »
Hello,
Does anyone know how to read in g100 a/d inputs in vb.
and how to output data on D/A outputs.??
I am trying to build external FeedOverwrite pot.
John
Re: G100 A/d inputs
« Reply #1 on: August 06, 2007, 09:35:50 PM »
I will try my best to look at this for you in a couple of days if no-one else has you straight. I'm running on a BOB right now and will be a couple of days before I finish the job it is running.
Re: G100 A/d inputs
« Reply #2 on: August 07, 2007, 01:54:49 PM »
Are you brining in the Inputs and outputs on the Modbus? If so, then use the:
y=GetInput(x)                        'x is the "Index number" of the modbus register your brining in
FeedOver=(y/*****) times 100              '****** this is your diverder it will be a number = to how many bits are in your register type (8, 12, or 16 bit), and give you a number 1-100
SetUserDRO(1200, FeedOver)        ' sets a user DRO to what your over ride is
SetModOutput(x, *****)              'This sets a 16 bit, word going out to "Index x", if you need to use less than 16 bits(native Modbus output is hex), use bit masking.
Scott
Re: G100 A/d inputs
« Reply #3 on: August 07, 2007, 03:24:34 PM »
i AM USING G100.
 i DO NOT KNOW HOW TO ADRESS THE A/D AND D/A
OF G100.
LIKE
GET( CHANNEL1)
 WHAT IS THE ADRESS AND WHERE DOES THE DATA GO.??
OR SET (cHANNEL4(OF THE D\A)??
THANKS
