Hello Guest it is June 10, 2026, 09:49:01 PM
Author Topic: Pendant/control panel with PIC 18f4221.  (Read 11324 times)
Offline PerE
  •  16 16
« on: August 05, 2007, 05:57:17 AM »
Hello all.
I want to build my own pendant/control panel for my router and i am going to use a PIC 18f4221 microcontroller. I want to learn to program this unit and use it for controll Mach3. Has anybody done this and what are the hints ? What do i have to think about when i am doing this ? Be gentle to me because it´s hard to learn an old dog (46year) to sit.  ;)
Per
Re: Pendant/control panel with PIC 18f4221.
« Reply #1 on: August 05, 2007, 01:46:29 PM »
You might want to start out with one of these as it will give you easy ModBus interface and a few people here on the forum can give you some tips,  I'm still learning this CubLoc thing.   It is very easy to use even for me:)
http://cubloc.com/product/01_01.php?PHPSESSID=e0f0bcf90b5e4678f73113b69cde25af
Offline PerE
  •  16 16
« Reply #2 on: August 06, 2007, 03:11:27 AM »
Thank you but i already have my processor (PIC 18F4221) and i want to program that one for my application.
I want to learn ASM (assembler) and i want to build my own pendant/control panel.
Per
Offline Whacko
  •  239 239
  • Happy Days
« Reply #3 on: August 06, 2007, 05:40:22 PM »
If you have never programmed before, youre up for a steep climb. I use PICS for many years, from 8 bit to 16 bit dsPICS. I would suggest you purchase a demo board (PICDEM2 PLUS) and an ICD2 from Microchip, but if the cash is low, there is another way. I implement the modbus on the dsPIC30F6014A and the dsPIC33 range which gives 40MIPS. The modbus is advanced programming, you need to implement CRC (Cyclic redundancy Check).
Whacko
Nothing's impossible
« Reply #4 on: August 07, 2007, 09:10:33 PM »
^^ What he said
Offline PerE
  •  16 16
« Reply #5 on: August 08, 2007, 06:20:04 AM »
Thanks for the replies. I have purchased a WISP628 and i have already started to program the unit.  ;)
Per
