Hello
Guest
it is
June 10, 2026, 09:50:33 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
limit switches and cable sheilding
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: limit switches and cable sheilding (Read 20173 times)
SimonD
143
Re: limit switches and cable sheilding
Reply #10 on:
August 11, 2007, 04:45:16 PM »
Thanks for the explanation of that the capacitor does and the affects of higher values. I will get some 0.1uf's with my next electrical order and replace the ones I am currently using.
Simon
cjmerlin
194
Reply #11 on:
August 12, 2007, 05:53:35 PM »
Glad to help..
Regards
John
vmax549
Reply #12 on:
August 13, 2007, 08:19:04 PM »
When you wire all the switches in series you create a really long attenna. THe caps should cure the problem. Also vibration can trip a switch.
Print
Pages:
1
2
Go Up
« previous
next »
